跳转到主内容
Fourth generation of iPad, released November 2, 2012, available in 16, 32, or 64 GB models. Model Number A1458
218 个问题 查看全部
New Digitizer not responding to input
Have an IPAD 4 WIFI that had a cracked screen. Ordered a new one and replaced it with no issues during installation. Reassembled it but the screen is barely responsive and doesn’t work at all in most places.
The old screen was still working just cracked.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Probably the digitizer cable being pinched between the housing of the iPad and the screen. It needs to be folded in a way that it doesn't get squished when the glass is installed.
Always remember to test digitizer before install. You'll need to replace the digitizer again unfortunately.
这个答案有帮助吗?
得分 2
3条评论:
The cable isn't squished. There's no sign of damage to it either.
I tested the digitizer as best I could.
完成的
In this case it's going to either be the digitizer going bad or the connector for digitizer needs cleaning.
Dust can get inside the connector so may need to be cleaned carefully with a soft brush and isopropyl alcohol.
完成的
I'd hope the digitizer didn't go bad its brand new.
I'll try to clean it out now
完成的
添加一条评论
添加你的答案
Tyler Evangelista 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 4
总计 45
