跳转到主内容
Over-ear headphones designed for gaming, generally tuned to enhance spatial awareness and built with a microphone to allow communication with other players.
519 个问题 查看全部
What is the proper wiring for HyperX Core Stinger TRRS connector?
I am rewiring a broken TRRS connector.
Unfortunately, the plug was so damaged that I am unable to probe the TRRS plug with the wires to determine the positions.
Since most HyperX devices are CTIA - the wiring should be:
Tip - Left Audio
Ring 1 - Right Audio
Ring 2 - Ground
Sleeve - Microphone
My issue is that it seems I have 6 wires.
RED / GREEN / Striped BLUE-COPPER / BLUE / WHITE with surround copper
The colors don’t seem to matter. Doing research on this yielded different color combination wiring from different headsets.
So I was looking for advice / confirmation on my wiring.
So for I have the audio working but not the mic.
(as an extraneous question, should the mic work if connected to a smartphone?
I wired it
TIP - GREEN (Left Audio)
Ring1 - RED ( Right Audio)
Ring 2 - Striped Blue-Copper (Ground)
Sleeve - White (Mic)
My direct question is:
Is the copper souring the white wire the Mic ground and attached to Ring 2?
Where does the blue wire go? Is that also a ground for the audio or mic?
I would really appreciate some help. Thank you.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
For those who may benefit from my attempts
Before you solder — You must find the connection on the end on a multimeter as some TRRS connector ends are wired differently.
Regardless of the color the wiring - HyperX headsets seem to always be wired as TRRS CTIA style:
(You can usually find out on the product documentation page)
Below is how I wired the HyperX Stinger Core with the color wires as reference.
Tip - Left Audio ( Green )
Ring 1 - Right Audio ( Red )
Ring 2** - Ground (Striped Blue-Copper color + Copper outer “shell” of the White wire)
  • There may also be an additional colored wire as another ground. I had a Blue wire I attached to Ring 2
Sleeve - Mic ( White )
All of the wires must be “stripped” before soldering as they have thin enamel coating.
Stripe the wires by using lighter to gently singe the coating off. Be careful as the wire will quickly catch fire if exposed to a flame too long.
As for the Mic (white) wire, I recommend that you use the heat from the soldering iron to melt it off as I found using a lighter too harsh, and scrapping with a tool too difficult.
After, I recommend you use a blunt scrapping tool or sand paper to gently remove any burn residue.
When testing the AUDIO connections you must have the Striped Color (GROUND) connected or nothing will be heard.
When testing the MIC connection you must have the outer Copper wire grounded or the mic will not work.
After my wiring, I had FULL R / L Audio with volume wheel working and a functional mic.
Hope this helps others.
这个答案有帮助吗?
得分 3
2条评论:
Thanks, it really helped.
完成的
This info was just right thanks, I just fixed my boys cloud stinger headset bought in the UK circa 2018.
Had 5 wires, red was right, green was left, the white core of the copper was mic, the copper core around the white + the blue + the copper/blue twist wire all went to ground. Hyperx refused to give out any info.
完成的
添加一条评论
To help, the white one is surrounded by copper cables, so you need to separate.
这个答案有帮助吗?
得分 0
2条评论:
Thanks for this solution, but I have a question. Should I connect the grounds separately or twist the wires together and solder?
完成的
@dwayne mills You can twist them together and solder.
完成的
添加一条评论
添加你的答案
Milo 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 13
过去 30 天: 67
总计 3,225
