跳转到主内容
Android 4.0 tablet for children/ blue back cover and white face/ released 2012
26 个问题 查看全部
forgotten password how to reset this
Kurio 7S cannot remember password
回答此问题 我也有这个问题
这是一个好问题吗?
得分 14
8条评论
I can't remember my password
完成的
My ex daughter n law set a pattern passcode on my grandsons tablet yet she doesn’t remember the code. How can I reset this for my grandson? Thank you
完成的
i forgot my password
完成的
Forgot my password to get in the tablet
完成的
Forgot my password on kurio tablet
完成的
显示更多的3条评论
添加一条评论
4个答案
最有帮助的答案
Hi there!
After doing some a light Google search, I was able to locate on Kurio’s Support page on how to complete a hard reset for the Kurio 7s.
I’ve gone ahead and copied & pasted what they mention '''here''' on their support page on the Hard Reset.
In order to reset to factory settings, please follow these instructions :
- Power off machine.
- Hold down + first and then POWER for about 10 seconds, release both buttons once Kurio screen loads .
- When you get the open Android picture, press + to enter menu, use - to move down to "wipe data / factory reset" and press POWER again to choose.
- Next press - to choose "YES" and press POWER to start reset.
- Check for yellow text Formatting /data, formatting cache, Data wipe complete.
- Choose reboot system now and press POWER to complete process.
NOTE: This will erase data from your Kurio's internal storage such as Accounts, System settings and Downloaded apps. But music, pictures, and other user data won't be erased. Check "Erase SD card" if you want to clear all the data of the system.
It is also possible to reset only the Kurio Interface: Go to Parental area > Tablet Setup> Press "Reset the Interface to Factory Default Settings".
Once this has been done you will need to set the device up and perform all the updates, instructions for this are on this page.
Please feel free to contact Kurio Technical Support on our support page.
Hope this helps and best of luck!
这个答案有帮助吗?
得分 8
7条评论:
This isn't working for me. Keeps opening back to the Kurio, it's time to stop screen. It won't let me pass and the serial number is not working.
完成的
I didn't know the password but followed instructions above and it worked
完成的
do you have a password
完成的
idon”t know my password
完成的
I can't find "Android Picture"
完成的
显示更多的2条评论
添加一条评论
Hi Kevin,
The Kurio website suggests you reset your google password with: https://accounts.google.com/signin/recov...
(Here is the FAQ page where I found this solution: https://kurioworld.com/us/support/kurio-... )
I hope this helps!
这个答案有帮助吗?
得分 1
添加一条评论
I don't remember my password
这个答案有帮助吗?
得分 1
1条评论:
yes l forget pas
完成的
添加一条评论
I can’t remember my password
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
l.nikki.dodds 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 33
过去 30 天: 109
总计 18,202
