跳转到主内容
加入维修社区 - 创建账户
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
Random black screen after replacement.
I bought replacement screen from ifixit and just finished replacing it. Black screen randomly appears when I press the power button. The backlight still turns on and there is no other problems.
I reconnect the ribbon cables several times but the problem keeps appearing. Is it a screen problem or a replacement mistake? Which of the three ribbon cables is display cable?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Long vertical = digitizer
Short horizontal = LCD
Short vertical = front camera
Restart the phone or unplug the battery and plug it back in to try the replacement screen or after any changes…
Try the old screen to rule out a problem with the part.
这个答案有帮助吗?
得分 2
3条评论:
Thanks for the suggestions! The old screen does not have the problem.
完成的
You may have a screen that will work on an iPhone 5s not on the SE some 5s screens work on the se some dont...
完成的
Yeah, some aftermarket 5S screens do not work on the SE. Original 5S / SE or aftermarket SE screens will work fine on the SE however.
完成的
添加一条评论
添加你的答案
Enddle 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 1,056
