跳转到主内容
加入维修社区 - 创建账户
Apple 的第三代智能手表,配备可选的蜂窝网络功能,发布与2017年9月22日。
Does a LTE display work on a GPS only watch?
I there!
Will a Series 3 LTE display work on a GPS only watch? I’am asking because the price difference is 150 Yuan (the LTE variant is much cheaper…).
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
4条评论:
What model of watch are you putting the display on? Gonna compare the teardowns.
完成的
I looked at it myself, it seems the little gold antenna connector will not connect properly...
完成的
@BioMajuss are you sure that's the only issue?
If yes, you could easily work around by some manual wiring?
完成的
Hey dies the Apple Watch 3 40 mm Display works on the Apple Watch 4 Nike 40 mm?
i want to know ist to Save Money
完成的
添加一条评论
3个答案
There are some discussions on this but as I recall you cannot use different screens or there will be degraded operation.
这个答案有帮助吗?
得分 0
添加一条评论
I just tried putting a display of an AW3 GPS onto an AW3 LTE.
I even tried moving the original NFC module of the LTE version onto the GPS’s display and ended up with pairing issues.
Was able to solve the pairing issues by using the display + NFC module from GPS version but had to sacrifice support for Apple Pay.
There is already a discussion about this topic here: Why won’t my watch pair after screen replacement?
这个答案有帮助吗?
得分 0
1条评论:
Recently I had changed my screen on Apple Watch series 4
I don’t know which screen has fixed by technician but after change my watch very slow booting & I did erased my watch
Then while pairing to my iPhone it was unpairing automatically without any pop up
Is it caused with new screen or flex cable
Unfortunately I don’t have old screen
Please help to what is right solution
完成的
添加一条评论
Putting a GPS only screen onto a GPS+LTE watch would obviously have problems, did you try the other way around? A GPS+LTE screen onto a GPS only watch? Thanks
这个答案有帮助吗?
得分 0
1条评论:
I’ve put a gps lte screen on a gps only, it works and comes on but touch doesn’t work. Damaged force touch maybe?
完成的
添加一条评论
添加你的答案
BioMajuss 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 51
总计 3,170
