跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
How to test a water damaged 6S - test points
So I have a 6S which has been totally submerged In water and unfortunately the person did try to turn the phone back on, and did not do anything special to try to get the moisture out. I have looked at all, or at least in all the places which I could access with a microscope and no components seems to have any obvious damage to me, except maybe U5411_RF and / or C5403_RF, but thats a maybe ?
I have cleaned the motherboard in alcohol.
Anyway, the phone does not boot up and does not respond at all when powering the phone from either a battery or with a charger.
So where could I start measuring, at which components and places would be suitable to start testing?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Firstly I would check for a vcc main short. It most likely will have one. How you track it down depends on what tools you have. Freeze spray, flir cam or the old fashioned way with your tongue.
Update (05/16/2019)
C4127 would be the best to check vcc main.
这个答案有帮助吗?
得分 1
1条评论:
Thanks for your answer. Can't I measure with a multimeter? Which components do you recommend to check first if I want to check for a VCC main short?
I am not skilled in this particular area, only a little bit in electronics in general, but I would like to give it a try anyway, thats my only option at this point.
完成的
添加一条评论
添加你的答案
Jon Smith 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 6
总计 239
