跳转到主内容
Made in three sizes. The spin brush is identified by the serial number BC178RBCR.
5 个问题 查看全部
Power Cord connection loose, goes on and off when moved
How to take apart without destroying?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Ooh, you might be out of luck here. If you don't know how to solder, you'd be better off buying a new one.
If you DO know how to solder, the problem is likely the solder connection between the socket pins and the board. Resolder those joints, and you should be good to go. To open it, look for screws. Sometimes, screws are hidden in inconspicuous places, like under small adhesive pads or under labels.
Good luck.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Richard Wendel 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 188
