跳转到主内容
Released January 2016, Identified by model number BDP-S3700
Is it possible to open drawer if player won't power on?
player was damaged due to electrical problem.
Common solution given by Sony and others does does solve power on problem.
It’s dead.
Is it possible to open the drawer without destroying the disc that was inside when the player died?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Usually you have to take the cover off and remove the dvd player so you can slide the tray out. It only takes a couple of minutes.
这个答案有帮助吗?
得分 3
添加一条评论
Every disc-playing device has a small hole on the front side. This hole is for powerless ejecting the disc in case of a powerfailure. Have a look at the tray and put a needle, nail or something else thin in the hole and press on it. The tray will open and release the disc.
这个答案有帮助吗?
得分 1
2条评论:
paper clip preferred.
完成的
@ruggb A professional paperclip is the better tool for sure ;-) 👍🏻
完成的
添加一条评论
添加你的答案
Calvin Hilton 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 17
总计 433
