跳转到主内容
Thin, light and powerful with incredible sound and Wi-Fi capabilities is what everyone needs to have on the go.
45 个问题 查看全部
Is it difficult to change the charging port?
So i have to hold the cable in a specific angle for the laptop to load. Should mean, that the charging port needs an exchange. Not i dont have any special equipment apart from screwdrivers. Is it difficult to exchange that part?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
First you should try using a different charger. If that doesn’t work then you should go ahead and change the charging port. Its shouldn’t be a hard job it just takes patients and time.
这个答案有帮助吗?
得分 0
2条评论:
do you think the charger may cause the problem? If it were the issue, then shouldnt it either be working or not working, regardless of wether i have to permanently keep it pushed to the top side of the charge port
完成的
No it can be a loos wire in the charger. But there is still a chance that it's the charging port. I recommend you first buy a charger with returns just in case.
完成的
添加一条评论
添加你的答案
dj-paok 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 118
