跳转到主内容
Google公司发布的二代Pixel XL版本,发布于2017年10月19日。配备6英寸圆角P-OLED显示屏。纯黑和黑白两种颜色及64GB或128GB存储空间可选。
Why is there a a line on my screen?
I recently went to ubreakifix for a green line on the left half of my screen. They were able to replace the screen and fix the problem. After around 2 months, a thicker white line appeared in the same spot. What could some possible causes be for this issue to occur?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
My immediate thought is that they have used a compatible screen as opposed to a genuine screen. While compatible screens can sometimes be a much cheaper alternative to buying genuine, they can have issues in some cases.
Although with that said, I personally haven’t had any issues in my experience with compatible screens as we use them all the time in the office when replacing iMacs, but that’s a different ball-game. I think that it’s possible the screen may have been damaged again, as it may not be as rigorously tested as the original for durability.
这个答案有帮助吗?
得分 1
添加一条评论
Hi @laserjet25
I am somewhat familiar with the relationship between Google and uBreakiFix and I can say that you should have received an OEM replacement screen installed with OEM adhesive. All Pixel repairs should have a 90-day warranty so this problem could likely be fixed for free at any uBreakiFix location.
As for the cause, there are several possibilities such as a small type of frame damage that was missed or a simple defective screen assembly. Either way, I hope that you are able to get a warranty replacement screen.
Best of luck!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
hiboytest 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 4,000
