跳转到主内容
加入维修社区 - 创建账户
PS4 控制器型号 CUH-ZCT1。这款由索尼电脑娱乐公司于 2013 年 11 月发布的六轴 3.7 V 锂离子电池控制器维修起来并不复杂。(注:拆解指南不适用于此型号)
Problems with my 2 controllers
So I’ve had both of my controllers since the release of the ps4 back in 2013. The controller i use most has a problem where i would plug it in to the ps4 to charge, then it would look up for no reason without moving the right stick. My second controller i use less, has problems where running feels sluggish, sometimes closes out of menus, and sometimes shoots my gun without me pressing R2. How can i fix these problems?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Seems that dirt /dust has accumulated inside the Controllers. Cleaning the interiors of the Controllers should solve the problem.
这个答案有帮助吗?
得分 1
添加一条评论
One option would be to try resetting the controller. Under the L2 button there is a small hole on the back of your controller. Using an unbent paper clip, hold the button down for about 3-5 seconds. This will reset the controller. Now plug your controller into your PS4 and re-sync it for a successful reset. If this doesn’t work, then definitely try cleaning it out to see if that resolves the issue.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lance Beltrano 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 9
总计 109
