跳转到主内容
骑记电助力折叠自行车是小米第一次进入电动自行车市场的首款商品。 拥有250W高速电机,配备松下18650锂电池组。 禧玛诺内3速花鼓 以及力矩传感器,一次充电可以助力骑行45km。 它同时配备有行车电脑可以将您的手机通过特别的应用连接。 同时自行车也是可以折叠的。
Replacing Gear from Shimano Nexus 3 to Nexus 7
Is their measurement compatible? Will it just only the matter of replacing the internal hub and shifter?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
The shifting mechanism is different between the 3-speed Nexus and hubs with more gears. So you might be able to swap them out, but you’ll have to check your bike frame to see how the gear-change mechanism mounts to the axle and rear frame chainstays. Shimano also makes a variety of different Nexus models with different widths, so you would have to make sure you get a Nexus 7 model with the same hub width as your Nexus 3. Depending on the age of your bike, the correct Nexus 7 hub might be hard to find. Newer “Alfine” models have a totally different shifting mechanism that might not be compatible with your bike - you’d have to check your rear frame to see.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Adi Suryadi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 1,441
