跳转到主内容
期待已久的MacBook Air更新到来,带来了全新的英特尔酷睿i5处理器、升级了的视网膜显示屏以及众多其他更新。发布于2018年11月7日。
148 个问题 查看全部
How long your MacBook Air 2018 battery last?
so, I just got this MacBook Air 2018. not only it overheats very quickly, the battery drop is very significant. I use the MacBook from some light browsing using Safari, just for 30 minutes, and the brightness of only 40%, the battery drained about 6 to 7 percent. is that normal? because it’s like new and I rarely use this MacBook.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Best thing is to install this gem of an app CoconutBattery. It will allow you to monitor your battery usage. Take a snapshot of the main window and post it here for us to see as well 在已经存在的问题里加入图片.
Frankly, your system shouldn't need a new battery yet as its still too new. But lets see how its doing just the same.
As you stated it is overheating it sounds more like you have something running which is sapping your CPU’s processing causing it to run too hard given the fact you are doing light web browsing. Open Active Monitor app and sort on the % CPU what are the top 5 processes when the system is hot. You might want to get this app TG Pro its one of the better thermal monitoring apps.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Steffi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 84
