跳转到主内容
The Xbox One Model 1698 Wireless Controller was released by Microsoft in 2015 alongside the Model 1697 controller. This controller is similar to the Model 1697 with internal modifications. It has more features than a basic controller, such as, removable thumbsticks and metal D-Pad buttons. The controller is primarily designed for console use, but is PC compatible.
My controller won't connect wirelessly anymore.
My elite controller won’t connect via wireless anymore. It will work with a USB cable but once the cable is removed it turns off. Can this be fixed by replacing the motherboard?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Not sure if this helpfull but I had the same problem with a regular controller. my problem seemed to be my rechargeable battery pack. every time one went dead I would swap it over to my fully charged one but I had to connect it via usb to sync it. all it would do is slowly flash when turned back on. the battary parks where running out of life I.e not holding much charge anymore because when using regular double aa my controller would sync fine like it does with my knew battery packs.
这个答案有帮助吗?
得分 0
1条评论:
Nope, the problem isn't the power source. New battery packs or new AA's don't work. Unless it's physically connected to the xbox via usb, it doesn't work.
完成的
添加一条评论
If your Xbox One Wireless Controller is not syncing or connecting to your Xbox console, see the Xbox One Wireless Controller Won’t Connect to Console problem page for possible causes and solutions.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kainoa Kaku 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 587
