跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
Display not working after Arduino crash
I am in desperate need for answers. Today I plugged my Macbook Pro Retina Early 2015 into an Arduino Uno to upload code to it and my computer went black. I tried to reboot it and got the startup noise but nothing showing on the screen. I reset PRAM and SMC to no luck. Hooked it up to an external monitor and it works fine. This computer has no history of liquid damage. I opened it up and cleaned and reset both ends of the LVDS cable and still the screen is back. What could possibly have happened and how can I fix it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Are you able to see a faint image on the display when you shine a flashlight into the Apple Logo?
Can you see the image with an external monitor?
完成的
I can see the image on an external but not through the apple logo
完成的
添加一条评论
1个答案
最有帮助的答案
If I understand it the external is working but the internal is not visible when you shine a flashlight in from the Apple logo in the lid if that’s correct your internal display cable (iDP or also called a eDP cable).
Let’s disconnect the cable from the logic board and take some pictures of the cable connector from both sides and also take some pictures of the logic board connector so we can see connector and look into the connector and post them here for us to see 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Eli Rosen-Duran 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 82
