LCD goes black when clicking in the lcd
Hello! :)
I am working on a iphone 6s. I have an issue when installing the LCD. When i install it and put on the plates the screen still works. But when i click in the screen it stops working. So the screen only works when loose in the frame and not mounted correctly. When i pop off the screen it still does not fire up again
I have tried the following
- pressing the powerbutton and home button at the same time.
- Disconnecting the battery and reconnecting ( atleast making the LCD work again)
- Using another original LCD (still not working).
- Reapplying the connectors for both LCD and battery
- Tried without plates over both battery and LCD connectors
- tried without backplate.
The LCD will only work when not mounted all the way in the phone, and work without issues untill i install it completly.
Does anyone have experienced the same issue or have any idea how to solve it?
Update (05/10/2019)
The issue is fixed. The grey/silver notch on the LCD flex cable made contact with the ear piece mounting bracket. I made some spacing between these two and now it is working perfectly! :D
1条评论
I cant seem to find Any spots that is not alreaddy covered
由 Thomas 完成的
