跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
Home Button Very Weird Problem :@
Hi, I have restored my iPhone 3Gs using DFU mode and the home button is working fine (also done a soft reset and the button works fine), but now when I use the phone properly in the iOS the home button does not work at all, so the home button only works when doing restores in DFU and soft resets, rather strange.
When doing restarts or putting the phone in DFU I never had the two prongs connected to the charge dock, is there a different circuit for restarts and DFU modes?
any ideas what it could be?
Thanks Chris
iOS 4.3.3
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
Turn iPhone off, and carefully reseat Flex Cable #4 (the Dock Connector Flex Cable). Probably the right most Flex pins are not seated all the way down to make contact with the Logic Board Connector. Seat it down all the way.
这个答案有帮助吗?
得分 1
1条评论:
Thanks for the help, still no success, I tried removing cable 4 from the logic/b, and then soft resetting to see if the home button still worked and it did, do you know are there two different connections to the logic/b one for system (soft reset/DFU and one for phone function
Thanks Chris
完成的
添加一条评论
I am also having the same problem. It is very frustrating and I cannot figure it out...also, volume up botton does not work but volume down button does. What could be the problem here?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chris Moss 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 447
