跳转到主内容
Sony CFD-S05 CD Radio Cassette Player was released in 2010, and has the CD-R/RW playback function.
25 个问题 查看全部
Why did my radio stop receiving any am or fm receptions
my sonyradio cd and cassette playecfd-SO5 stopped receiving any am/ fm siginals, once in long while it works again , if i turn it off and on again i makes aloud pucking sound , then i get nothing just dead static ,very low volume static sound , if i turn the volume up the static will not increase either ,when i try to scan for a channel , it will not pick up anything, I live were there is a lot of stations to pick up, , but the casett deck will work, and no cd sound either? i brought it to a store to get fixed . he plugged it in and it worked , Took it home pluged it in . it worked , turned it on again next day , same problem , no reception on all levels am or fm? made a loud pucking sound ,when turning on the on button , turned it on agian this time no pucking sound and still no reception?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @ulma
Some things I would like to check....
How do you power it up?
By mains or battery?
Had you tried observing if using battery... what is the outcome.
You will need to open it up and check on the mainboard for any leaky capacitor.
check for any cold solder joints and also the contact to the antenna is properly connected / soldered.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
terry 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 25
总计 797
