跳转到主内容
A singing, dancing, pink pony that responds to its included toys and outside stimulus.
4 个问题 查看全部
Head/neck very loose and clicking
When I turn it on some of the moves it tries to do it clicks. Not positive what’s wrong but when it’s turned off the head and neck move around so I believe it’s either spring or motor there. I see the information for replacing motors or springs in legs but I believe it’s the head/neck. And where do I get the parts from to replace them??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
Upon dissembling the toy, I found one of the reasons why the neck clicks. there is a small plastic tab on the tip of the black neck coupler.
this slides into the potentiometer located in the white base of the neck
. This controls the rotation of the neck and prevents it from clicking. It got broken off. I got lucky and found the broken tab when I took apart the toy and managed to glue it back it on. I don’t know if the glue will hold. If it does not I will try and scan the base and see if I can 3d print it. I will make the .STL file available if need be.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jessica Hummell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 283
