跳转到主内容
Repair guides and support for electric and gas-powered high-pressure sprayers sometimes referred to as power washers.
42 个问题 查看全部
No pressure in my karcher2
I put a bin liner loosely over my karcher 2 because it started to rain,then went back to the spraying and forgot to take the bin bag off.
it ran for a while,then made a awful noise,and I was very quick to turn it off.it will turn on but there is no pressure,can you please help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi John,
Sorry to hear! Have you tried clearing the unit in case air is trapped inside? Here is a guide from Karcher’s website.
To bleed the pump of any air, turn the machine off and disconnect the high pressure hose and trigger gun from your power washer. With only the garden hose connected to the machine, turn on your water source and allow water to run through the pump of the machine for 20 or 30 seconds. Turn off the water and connect the high pressure hose and trigger gun and try using the machine again.
http://www.karcher-help.com/index.php?/K...
Have a look through the above link as well.
I hope this helps in some way.
这个答案有帮助吗?
得分 0
1条评论:
Thank you mark,but I’ve already tried that option
完成的
添加一条评论
添加你的答案
John Richards 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 297
