跳转到主内容
加入维修社区 - 创建账户
索尼电脑娱乐发布的电视游戏主机。于2013年1月20日发布,2013年11月15日上市。
My ps4 doesn't turn on and has a solid blue light. What can I do?
My PS4 suddenly stopped working when I tried to turn it on. None of the buttons on the console work so I can’’t even eject the disc. I have tried unplugging it multiple times and leaving it unplugged for weeks in a row. Can you help me please?
Thanks so much!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Since you have tried unplugging the device lets try other options. If possible, try replacing the power cable with one from a any other PS4 or PS3 and see if the issue persists when turning the console on. Just to make it sure that your power cable is ok.
See if the hard drive is seated properly and isn't damaged to fix the blue light of death
  1. Turn off your PS4 completely by holding the power button for at least 7 seconds
  2. Once the power indicator has completely shut off, remove the power cable, then all the other cables from your PS4
  3. Slide off the hard disk drive bay cover and check if the internal hard drive is seated properly
  4. If possible, unscrew the one screw that is holding the hard drive in place and re-seat it back into its slot.
  5. Once you've checked or reseated the drive, put the hard drive bay cover back on, plug all the cables back in and see if the problem persists when turning the console on
  6. If possible, check whether the hard drive itself works by setting it into another PS4 and turning it on.
Please try this and get back with status….
这个答案有帮助吗?
得分 0
2条评论:
Have you had any luck fixing this? Mine is the same and I can't find answers
完成的
@jswain1809 please describe your issue.
完成的
添加一条评论
添加你的答案
Joe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 1,582
