跳转到主内容
Repair guides and support for C/K pickup trucks sold by General Motors under the GMC brand, including the GMC Sierra.
77 个问题 查看全部
Why is my 98 sierra backfiring and burning double the fuel
I changed the plugs and wires , oil and fuel filter on my 98 gmc sierra z71 k1500 with a 5.7
I had a wire on each side crossed over somehow and drove it before seeing the problem the second time looking .
Now it burns about double the fuel and runs like it's dieing on takeoff with a load on it , not to bad without a load , but it's backfiring and spits a d sputters on takeoff and with or without a load tries to and does at times shut off when taking off at a light . Pulling up codes low air input at MAF and cam shaft position sensor, I've changed the MAF but no change .
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
reckon you may have fried or gas fouled the spark plugs at those two cylinders you had crossed? if so, those cylinders still may not be firing, meaning your power is down by 25%, and might also be dumping raw fuel into catalytic converter, impeding exhaust, etc., at the same time.
replace those 2 plugs first, i would guess.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ennis Bohannon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 292
