跳转到主内容
The Dell Chromebook 11 3180 is a cost-effective, student laptop that runs on the Chrome operating system. It was first released on Feb. 7th, 2017.
Why is my dell chromebook 5190 2 in 1 not charging?
I’ve plugged my chromebook and the white light on the corner led light is on only while it’s plugged in but it is just a black screen and it’s been charging for 7 hours and won’t turn on and i’ve tried everything. holding power button, holding the power and reset button, turning up the brightness, etc.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
May be a faulty battery that isnt accepting the charger port, or it may be a damaged motherboard or the battery is burnt out completely. Try replacing the battery first.
这个答案有帮助吗?
得分 0
添加一条评论
You’ve probably figured this out already, but here’s for the late-viewers. The Chromebook power shorted out on it. What you need to do is unplug the battery, and plug it back in. And then plug in the power cord, and it should start charging. We have this issue at my High School, I help fix every Chromebook that comes in.
这个答案有帮助吗?
得分 0
添加一条评论
Well if you bended your charger to plug in your computer and if you kept on doing that it would break the inside of your computer so you couldnt charge it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Genah L 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 1,384
