跳转到主内容
2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
467 个问题 查看全部
Spilled cherry juice on my mac
I spilled little bit of cherry juice on the upper left side of the keyboard.
Turned it off and put it upside down. Than I turned it on after 30 minutes(I know I shouldn’t have but had to) and worked fine(worked for 7hours). It still works well, just ‘A’ button feels little sticky from the inside when I press it.
Is the big trouble over or can my mac stop working if I turn it on?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Short of taking the whole thing apart, I would shut it down, disconnect the battery, and suspend it keyboard-side-down between a couple of blocks or cans or something. Then spray 99% isopropyl into the keyboard to wash out as much of the syrup as you can. Aim a small fan upwards to help it dry; let it sit (always keyboard-side-down so the liquids can't drip further into the computer) overnight to make sure it's completely dried out, then try the keyboard. If it still sticks, repeat. If not, reconnect the battery and give it a go.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
zuratodua 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 67
