跳转到主内容
索尼的新一代电视游戏机,于2013年2月20日发布,并于2013年11月15日开售。
1697 个问题 查看全部
PS4 Model CUH-1216B only has 2 screws, how do I open it
Hello, my PS4 Model CUH-1216B only has 2 screws on the back. Can you please explain how to open it. Since a few days it won’t start up again. Starting it, I only get a screen saying “connect the dualshock 4 with a USB-cable and next press the PS-key”, which doesn’t do anything. I got it once in safe mode and tried to reinstall everything, but then it crashed again and now I am stuck! Does anyone has an idea about what could be causing this? Thanks for your support.
Bob
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
If you have already exhausted all the options in safe mode with the full PS4 initialization firmware file downloaded into the USB then it’s going to be a bad hard drive.
Software update can fail with error code if the blu-ray drive is not working. As long as you can eject and insert discs into the PS4 the blu-ray drive should still be good.
更换PlayStation 4的硬盘
PlayStation 4 SAA-001/SAB-001 Hard Drive and Bracket
PlayStation 4 SAA-001/SAB-001 Hard Drive and Bracket图片
产品
$29.99
这个答案有帮助吗?
得分 1
添加一条评论
Press and hold the power button until you hear two beeps: one when you first press and another seven seconds later.
这个答案有帮助吗?
得分 0
1条评论:
i can't click on the other options except for number 7 , what should i do ?
完成的
添加一条评论
添加你的答案
Bisshop Jyr 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 12
总计 1,449
