跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
873 个问题 查看全部
Wifi disconnect , static noise when calling.
Hello you guys,
my iphone 8 plus have some problems that i cant figure out.
when i am calling with a person , i hear sometimes static noise , also the other person cant hear me well when the static noise appear, when during the call i put it on speaker everything is fine no problems at all.
my wifi network is also a little bit poor,
when i search for network i see all my networks with good connection but after a few sec the wifi networks resets, and thre are no more networks,
this is probally logic board damage after a fall or when the battery Get lose i have to replug it in.
i hope someone can guide me the right way or know what it is
( phone is completly refurbished also, ( battery, lcd, housing) phone is heating up at the top right corner when playing games.
and sometimes at the dock connector side when playing sound.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
who refurbished it? sounds like you have poor connections at a guess, try reseating all the flex cables and make sure all the plates are on, also check the wifi antenna is grounded to the shell at the top of the phone. as for the static maybe replace the front cam flex and earpiece.
这个答案有帮助吗?
得分 0
1条评论:
The problem with the static noise is on both sides,
Caller and reciever , and i did the full refurbish.
完成的
添加一条评论
添加你的答案
glennjacobs 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 41
