跳转到主内容
A collection of guides and support to help with washer repair.
3473 个问题 查看全部
Soapy clothes in washing machine
Clothes are still soapy after washing cycle has finished. I have cleaned the machine, used white vinegar to get rid of soap suds, the machine runs clear on an empty cycle. I have changed washing liquid and using only a small amount. The machine is draining, the pump isn’t making any weird noises, I’ve checked the filter, checked for blockages in pipes and water is running through. What else can I try? Thankyou
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
  1. Too much Detergent added.
  2. Overfilled Washer.
  3. Drain Pump not working or clogged.
  4. Drain Hose may be bent or clogged.
  5. Water Supply Hoses bent or kinked.
  6. Water Supply Valves not fully open.
  7. Switch or Control Board malfunction.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
EmmaSmith 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 170
