跳转到主内容
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
707 个问题 查看全部
What is this charging-related component?
I got a Switch in that isn't charging. It was assumed it was a charging port issue, but upon closer examination, I saw this:
It clearly has an “S”-shaped hole in the top — it's fried. That component connects the upper copper plane to the fourth pin on either side of the charging port (of the row that's exposed in the back) (VBUS?).
The upper copper plane leads to the charging IC, second pin on the bottom right:
So, likely the charging chip must be replaced, however even after replacing it, I'm still left with that component with a hole burned in it. Can anybody identify the component? I'm guessing it's a fuse or ferrite bead, but it might even be a resistor. In any case other than a resistor, I could just jump the pads with a wire and probably be fine. But, if it is a resistor, knowing the value would be very helpful.
Chuck R
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Hi Chuck,
The component in question is a 0.02 Ohm resistor. The board I used to confirm this has a slightly different configuration but the pathways go to the same places.
Hope this helps!
Happy fixing :-)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Charles Ricketts 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 6
总计 135
