跳转到主内容
加入维修社区 - 创建账户
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
Two problems with iPhone 6; can’t hear and battery dies fast.
Question 1.
To start off, I bought an iPhone 6 (silver/ 128gb) about two years ago from someone, used of course.
It was fine for a while, but then I noticed that the volume was low. I checked online for solutions and made sure it was at max volume in general/ settings. Even at full volume, you can barely hear it. Note that this only happens with phone calls. I tried to trade it in, explaining that everything was fine except for that issue, and I was given the explanation “It’s an internal software issue, it cannot be sold”, but I don’t believe that.
So my question is, is it possible I may just need to replace the hardware and install a new ear piece/ speaker?
Question 2.
The same phone also has an issue with battery life. Note that I recently replaced the battery with one that has a little more juice. I believe the original battery life is 1810 MaH and the new battery currently inside it is 2050 MaH.
I did a test with with this iPhone and another iPhone 6 (pink/ 64gb). I charged them both before work (7 hour shift), came home same evening and the Silver iPhone (128 gb) died while the pink iPhone (64 gb) only went down by about 10%. Both on standby and both were recently given the same brand new 2050 MaH battery.
Is there possibly something else that’s wrong with the Silver iPhone, maybe perhaps with hardware? Something I could replace?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
First off, the earpice could just be dirty, usually the mesh gets full of dirt and makes its way inside the mesh and compacts, this is easy to resolve by taking the earpice out and cleaning this area. Worst case replace the earpice also which is cheap.
secondy the battery, even though you bought a high capacity battery its probably just fancy marketing label but that's not your problem, you could try a new battery if the replacement is worse than your original as batterys can be defective, or you could have a hardware issue which maybe hard to diagnose, a reputable repair shop should help you with this, it may have water damage inside.
这个答案有帮助吗?
得分 2
添加一条评论
  • Replace the earpiece & clean the metal mesh for the speaker
  • Try another battery and make sure its actually charging properly with a USB ampmeter
The 6 isn't available in pink only the 6s (and above) if so are u comparing a 6 to a 6s and did they both have the same software version? Running apps, etc…
这个答案有帮助吗?
得分 2
2条评论:
My apologies, I meant to say rose gold. But I also double checked, and again, excuse me for the misinformation. It is actually just regular gold and it is indeed a regular iPhone 6.
When you say software, are you referring to the iOS? Both phones are up to date and have few apps running since I don’t use them at all. I’m really just wanting to learn to repair the damage to them and possibly resell them.
完成的
@alecciobelfont Since you have already a known good and possibly a bad battery the easiest thing in my opinion is to just swap the two. If you still have the battery drain that points to a short.
完成的
添加一条评论
添加你的答案
John Yuki 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 99
