跳转到主内容
A1708/EMC 2978—于2016年10月上市,这台入门级MacBook Pro保留了它传统的功能键(相对于OLED触摸条)。功能键版本带有英特尔酷睿i5和2个雷电3端口。
216 个问题 查看全部
Access to files on SSD drive.
Hi,
Can you please call me I’m looking for an adapter that allows me to plug in a 2016/2017 non touch bar SSD drive to either a USB-A or USB-C port to read and test drives externally.
I would need about 10 of them.
Apple Blade SSD 5GA 34+22 Pins NVMe
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Sorry we don't call people - To expensive!
Sadly your model uses a very different SSD connector as you can see in this 带功能键版本的 MacBook Pro 13寸 2016年末款拆解 jump down to Step 10.
So far no one has created one. Give OWC a call to see if they have anything thats the best I can offer you.
Your only option is to get access to another Fn MacBook Pro which you can swap out the SSD to gain access to your files.
这个答案有帮助吗?
得分 2
添加一条评论
Would installing my SSD into another working mackbook pro work exactly the same? meaning i would need the apple id and password from my SSD?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
kirk 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 1,958
