跳转到主内容
加入维修社区 - 创建账户
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
Rear facing camera won't auto focus
So I have a phone here that is not auto focusing. I'm not sure if it would be a camera issue or a sensor issue.
When you tap on the screen, it will not try to auto focus like it normally will but you can zoom in and out and looks a little bit fuzzy. The front facing or selfie camera works perfectly.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The motor is damaged on the rear camera so it can't focus. This happens usually after the phone is dropped numerous times.
To fix this it will require getting the rear camera replaced.
iPhone 8 Rear Camera Replacement
Replace a rear-facing camera compatible with the iPhone 8. Fix focusing or sensor issues.图片
产品
$30.99
这个答案有帮助吗?
得分 0
1条评论:
Thank you! That's what I was suspecting but wasn't sure and didnt want to just buy a camera to test it out. Thanks again!
完成的
添加一条评论
添加你的答案
Fredrick Rios 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,421
