3.7V 1500mAh 583460 Li-ion
Hello, I’d like to change out my super awesome ps3 wireless headset battery as my usage time has dropped from 10 hours or so to 5 hours. The old is 3.7v 570mah LIP1472 battery and perhaps 8 years old with hundreds of charges. The 3.7V 1500mAh 583460 Li-ion is slightly larger than the original (3mm longer (L) and 1 mm thicker (D), while 4 mm narrower (W)) and I can modify the unit for the size difference. I am hoping to get double the “new product” usage rate at maybe 20 hours per charge. Would this battery work in this application?
1条评论
Paul did you ever get this issue resolved? I watched the only video online but did not see the battery after he removed the circuit board, Any idea where it is? How is your replacement battery working? I see the link no longer has the battery avaiable.
由 Larry 完成的
