跳转到主内容
Google公司发布的二代Pixel XL版本,发布于2017年10月19日。配备6英寸圆角P-OLED显示屏。纯黑和黑白两种颜色及64GB或128GB存储空间可选。
20 个问题 查看全部
Rear camera not working after swapping into new chassis.
I bought a used back case for my phone from iFixIt. I carefully swapped everything over according to the guide. I replaced the battery with a new one and replaced my cracked screen as well. Everything seemed to be working until I went to take a picture. The app opens for half a second and then closes again. I tried all of the fixes online except for the factory reset. I do not believe this to be a software issue, but possibly something I did wrong.
I took the phone back apart but can’t find anything that looks odd or out of place. The thing is, when you transfer the motherboard you don’t even disconnect the camera. However, I did the old “unplug it and plug it back in” anyway. First I unplugged the battery then unplugged and replugged the rear camera, then the battery. Still the phone app simply opens for half a second and then closes.
What could I have messed up? I would just get a replacement camera but I’m very doubtful that would fix it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论:
Try backing up the phone and just system restore it.
完成的
Did that. Nothing changed. Replaced both cameras with ones from ifixit. Still no help. The camera app just crashes.
完成的
添加一条评论
3个答案
i actually just dealt with this same issue with the same exact model of device. What ended up happeneing to the device, we did end up replacing the rear camera, that did fix the issue with the camera crashing moments after it was opened. I do have to ask if you can open your camera app to the selfie camera or does that crash as well?
这个答案有帮助吗?
得分 0
1条评论:
So replacing the rear camera fixed the issue? I just did a factory reset which of course did not fix the issue, but changed it. Now the camera app will stay open for a few seconds but I get the error "the camera device encountered a fatal error." Changing to the selfie camera doesn't help. I still get the same error after a few seconds.
完成的
添加一条评论
I am also having this issue, just replaced the rear camera for my step dad’s phone, and the app just opens up but with black screen then closes after a few seconds saying that the app in unavailable, I need to first back everything up and perform a factory reset; hopefully this repairs the software part of the problem… Any suggestions?
这个答案有帮助吗?
得分 0
添加一条评论
Have you ever solved the problem? It happened to me after a repair... :/
Tried to change camera and did not solve the problem.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Michael Gleason 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 19
总计 701
