跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
Power Button didn't work (new case)
Hello together,
the case of my SE was broken, so I brought a new one and transferred everything in it.
After the first test I noticed that the power switch didn’t work. so I found out that the new button was different. In the picture you can see that the pin on the right side is missing and in the old case there was a cable.
I tried to install the cable in the new case but it didn’t seem right and also didn’t work.
Thanks for your help!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
U can remove the pin using some thin pliers or something similar grab it in the middle and try to pull it up and out of that hole then push it into the new housing, the cable pictured I think is for grounding for the antenna or something like that, that wont affect the power button… the power button itself the flex could be damaged and in the picture it doesn't really look plugged in fully…
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
troche turnout 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 164
