跳转到主内容
加入维修社区 - 创建账户
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
MacBook Pro internal screen doesn't work but an external monitor works
Hey all,
My Macbook Pro (Mid 2012) has a problem. The screen is black when I boot it up, but when I plug it in to my external monitor it works.
Things I tried:
  • Reconnecting LVDS cable
  • PRAM reset
  • SMC reset
  • Disconnecting the battery for a few minutes and reconnecting it again.
  • Removed and re-inserted RAM sticks.
I don't know what I can do at the moment. Are there more things I can try or should I get a screen replacement?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
Shine a flashlight through the Apple logo in the lid are you able to see your desktop and the icons?
完成的
Hey Dan,
Thanks for your quick reply. No, I don't see any icons or my desktop.
完成的
Turn off the system and disconnect the LVDS cable take a picture of both the cable (both sides) and the logic board so we can see the connections as I'm suspecting there's some damage 在已经存在的问题里加入图片
完成的
I added some pictures. I hope this will give us an answer.
完成的
添加一条评论
2个答案
最有帮助的答案
Well the good news is the cable and the logic board connector are in good shape. I don't see any broken pins or other physical damage. I assume you've reseated the connection and it still is not working.
The bad news is you can still have a bad display or the logic board is damaged.
Can you tell us a bit more on what happened before the display failed. Did the system get a bang or get wet?
What does System Report show for the display under Graphics/Displays (it may not be listed). Also, I would run diagnostics to see if any errors popped.
At this point I would use a spare display, carefully plugging it in to see if it worked. If it does that cinched it! If not the logic board output switching logic has problems.
这个答案有帮助吗?
得分 1
3条评论:
Hey Dan,
Thanks for your response. The laptop got dropped and after that I didn't got any video on my screen. Under the tab "Graphics/Displays" I only saw my external monitor. I will run a diagnostic test later today and I will let you know the results.
完成的
I tried to run the diagnostic test, but I got an error. It said: Cannot load "EFI/Drivers/TestSupport.EFI/". What should I do?
完成的
You'll need to patch your diagnostics to fix it Fixing Apple Hardware Test (AHT)
完成的
添加一条评论
The cable if probably dead or the connector is if there is no picture. The GPU might also be dead. If that is the case, get it to a shop with board repair or replace the screen cable/connector.
这个答案有帮助吗?
得分 0
1条评论:
The 13" MacBook Pro's don't use a dedicated GPU the built-in graphics engine within the CPU is used. Besides an external monitor works so that rules that out.
完成的
添加一条评论
添加你的答案
Marwin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 1,083
