跳转到主内容
加入维修社区 - 创建账户
The W123 chassis covers 240D's, 300D's, 300TD's, 280E's, and several other models of Mercedes coupes, sedans and wagons from model years 1977 to 1985.
Fuel Float Repair Info
While cleaning the fuel tank float on 1983 300D the aluminum wire (“V” shaped) which guides the float and helps send level info to gauge broke. I replaced it with same size copper wire. Would that effect the fuel gauge reading? What difference it makes if it is aluminum or copper while the other (“I “ shaped second wire in the unit) wire was copper as well.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
It will definitely affect the reading! But as far as I know, it should be okay if you never plan on driving with an almost completely empty fuel tank.
I don’t remember how much but the change will be in resistance to the wire so it will show either more or less than actually in the fuel tank.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
hhbabaturk 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 193
