跳转到主内容
Introduced in 2016, the Brother MFC-L6700DW monochrome laser All-in-One addresses the business needs of workgroups with higher print volumes. It boosts printing and copying at up to 48ppm. The large 520-sheet capacity paper tray holds more than a ream a paper for fewer refills, and for additional capacity add-on trays boost total capacity to 1,610 sheets.
9 个问题 查看全部
no power up when turn on
Not operational when turned on. Completely off
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
  1. Trace the power from source.
  2. Check the operation of the power switch (once in our office a printer’s power switch was found to be infested with ants).
  3. After that check the low voltage power supply board, if you can work out how to remove the covers.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Roman Misandzhi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 11
总计 403
