跳转到主内容
加入维修社区 - 创建账户
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
Home button - Clean or Replace?
I have a good-condition SE that still looks and works great. I’ve opened it to repair a few times in the past but at some point recently the home button stopped working consistently- Touch ID is fine and it clicks, but i have to press it just right for it to register. I eventually upgraded my phone but now I’m missing the SE.
I bought a new HB but am wondering if it’s worth just cleaning the inside first, and if so what’s the best way.
For some additional context, I popped the display open and shot some air inside and it improved for a little while, but eventually went back to normal.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
I think the actuator for the home button has worn out, you may need to find someone experienced with repairing the home buttons to fix that.
Otherwise you could replace the home button but you’ll end up losing the touch id / finger print unlock option.
这个答案有帮助吗?
得分 1
添加一条评论
I’d try cleaning it out carefully, try not to damage the flex cable etc. If that doesn’t work see if you can go to a microsolderer or something along those lines to see if they can fix it, I’d personally rather pay or spend time trying to fix it rather than replace it and loose Touch ID. :)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Erik 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 400
