Why will my DOSS Soundbox will only play 1 song on my TF card?
I have a DOSS Soundbox that is 2 years old. It has been working fine, but last Friday, it stopped playing the TF card I had in it. It would only play one song and then shut off. I tried clearing and reformatting the card, but it still only plays one song and shuts off. I’ve tried playing it while it is plugged into a power source, but get the same results. Do you have any ideas on how I can get this corrected?
5条评论
Can you reset the DOSS Box back to factory settings and try that?
由 Henri Grimm 完成的
Hi @weeroyer ,
Did you copy the song files in the same order back onto the TF card after reformatting it?
If you did, perhaps the 2nd song in the list has a faulty file.
Can you skip forward (use the fast forward button) to a song past the first 2 and see how it performs then?
Are all the songs only in .mp3 or .wav format?
由 jayeff 完成的
I'm afraid I don't know how to reset the Soundbox back to factory settings.
When I reloaded the TF card, I added several new songs. The songs are in a different order. The song it plays today is different than the song it played before I reloaded the card.
由 Diane 完成的
Where exactly is the reset button inside AUXIN(?)
由 Paco Jacobo 完成的
Ive been having a problem where in TF card mode it males a low beep twice and wont play ANY songs, It beeps twice then switches back to bluetooth mode, didnt have any problems before but all of a sudden it happened, Ive tried to format the card but it didnt work
由 Dominik 完成的
