Stop switch assembly location
Yamaha G22A gas golf car, where do I find the Stop switch assembly
Make sure the stop switch is bad before replacing… check your fuses….
这个答案有帮助吗?
Fuse is good cart motor will not shut off except with key Ibelieve switch is jammed on. Need location of switch.
Found the switch it is under floor panel. Lift up floor mat underneath by brake & gas pedals is a floor panel lift it out switch is underneath gas pedal. All accessible from top of machine.
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 337
