跳转到主内容
型号:A1419/ 2012/2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 专业版
330 个问题 查看全部
Fusion Drive HDD broken, replace only the HDD or chang it to an ssd
I have the iMac Intel 27" EMC 2546, and my HDD broken.
Now I have 3 options:
  • Replace the HDD 1:1 with an new HDD
  • Replace the HDD with a SSD
  • Replace the HDD with a SSD and remove the blade SSD
Now my question, the option replace the HDD with a SSD makes this sense because i have a Fusion drive, is it better to remove the blade SSD?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Before you can do anything you’ll need to break the Fusion Drive set How to split up a Fusion Drive
All three are viable. If your Fusion Drive config mets your needs then just replace the HDD with a new one.
If you want performance, the easiest way would be to replace the HDD with a SSD drive, but you still have the Blade SSD present which is mostly useless as a standalone drive.
If you want the ultimate performer, I would swap out the Blade SSD with as big a drive I could go with. It will offer the best performance! Its more work and costly but its well worth it (512 GB or bigger)! I would then put in a 3.5” SSHD drive for my content.
这个答案有帮助吗?
得分 1
添加一条评论
The blade SSD is going to be the fastest drive in the computer. They are faster because they don’t have a length of cable to run. Unlike the 2.5 SATA III SSD’s, the Blade drive is in a socket that is directly on the board. Keep this one and put your OS and applications on it for the highest performance. The HDD is only for storage, your operating system does not live on here. Granted it is not as fast, the HDD is the cheapest way to store large amounts of data. But since you have your OS on a blade drive, you will not see any performance increase in operation of your computer. The only advantage of having an SSD for storage in place of an HDD for storage would be that you can save and transfer documents between the OS and storage drives much quicker. But you need to decide if that is worth paying 2X the cost of an HDD. I say its not really that important if your OS is already on a Blade drive.
这个答案有帮助吗?
得分 0
2条评论:
@a_i_takeover - While the distance is shorter, its the interface that's just much faster (PCIe/NVMe Vs SATA)! Review this great guide which will give you the details why is so much faster The Ultimate Guide to Apple’s Proprietary SSDs
完成的
I did not realize I was incorrect in saying that. Thanks for the reference!
完成的
添加一条评论
添加你的答案
sunny 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 77
