跳转到主内容
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
Dim / Dull Screen
I'll start by saying Hi :)
A few days ago I bought an anti scratch vinyl front and rear cover for my iPhone 3GS.
followed the instructions and used the supplied water spray to help manover vinyl film.
spraied the sticky side of the vinyl and applied to front screen, then used the smoothing out air bubbles gadget to smooth out the air... some water did go into the speaker outlet. wasn't a great deal but since then my screen will not light up.
adjusted brightness settings and turn on and off the auto-Brightness opition, but still very dim screen. so dim you need to tilt the screen into the light to view anything.
What can I do :S
Thanks in advance for your help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
This is called No Backlight problem. Often due to water damage. Put the iPhone into a bag of uncooked white rice to help it dry out.
The Backlight problem can be due to LCD display damage or can be due to Logic Board Controller chips damage, two of them most commonly affected.
Let the iPhone dry out for maybe two days at least, see if issue resolves. At that time you can try a Reset to see if it helps.
If still No Backlight first step would be new LCD display
这个答案有帮助吗?
得分 0
添加一条评论
This happened on Sunday morning, No change as of today (Wednesday)
I've bought a new screen from eBay to change over...
anything I need to know about changing the screens incase I break things some more :(
Thanks for your help :)
这个答案有帮助吗?
得分 0
添加一条评论
Just go slow and be careful. You can do it. If it doesnt work, then you may need the coil replaced. That is done by desoldering the old one and soldering on a new one.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 729
