跳转到主内容
The sixth-generation Honda Civic was introduced in 1995. It retained its class-leading handling as it, along with the fourth and fifth generations, had front double wishbone suspension, the advanced independent suspension inspired by Honda's racing research.
53 个问题 查看全部
My headlight are not working nor are the emergency flasher lights
I replaced the whole Distribuator and after replacing the new one, my headlights no
longer work nor the emergency flasher lights and the stereo.  What could it be?   A modular possibly? 2000 Honda Civic
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
Did you check that fuse #5 (headlight, small light) in the under-hood fuse box is OK?
Also check fuse #12 (backup, radio)
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Lisa Garcia 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 57
