跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1364 个问题 查看全部
iPhone replacement screen does not fit the top
The original screen has metal drop in clips. The new one has plastic slide in clips on the top of the screen. Where can I find a replacement one with the metal clips on top with the proximity sensor and stuff. Please put links
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
You have an iPhone 8 or 8 plus most likely if the phone’s back is made out of glass and the original screen had 3 metal clips at the top of the screen.
Don’t try to use the 7 or 7 plus screen on that phone if that is the case because it will damage the screen connectors.
这个答案有帮助吗?
得分 1
添加一条评论
Hi
It seems like you are getting the iphone 8 plus and 7 Plus LCD mixed up. Yes the screens will fit, but the frame is different, hence it wont fix when you reinstall.
1) Check the model on the back of the phone. Its in the fine print. Just type it in google/on ifixit and you will get the model you have
2) Iphone 8 plus lcd is with metal clips and 7 plus is with the plastic clips on the top. If the original LCD has metal clips, likely its an 8 Plus
hope that help
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Stace neff 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 113
