跳转到主内容
The Xbox One X (Model 1787) is Microsoft's high-powered game console, succeeding the Xbox One S. The Xbox One X was released on November 7th, 2017.
151 个问题 查看全部
Xbox wont turn on
When the power button is clicked, the noise beeps like it is turning on and then followed by a high pitched screech and then it will turn off shortly after. the tv shows nothing other than a trouble shoot page and occasionally nothing, I've tried, plugging and unplugging, factory resets and nothing works
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
ok so, i hate being the one to admit this… but this happened to me before, but i caused it. Does the sound (sound) like its coming from where the fan is? Like maybe a mechanical screech? If so, its the fan hitting something inside. What i had to do was remove the casing (dont do this unless youre ok with voiding your warranty) and kind of bend the metal around it back into its original position.
这个答案有帮助吗?
得分 0
添加一条评论
Your vents might need cleaning. You can use a Compressed Air Canister, or just a simple vacuum. That fixed close to the same issue on one of my Xbox 360s.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Benjamin Vidjen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 510
