跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
My Display is working only in a certain angle
My Late 2016 MacBook Pro with Touch Bar has problems!
My internal display works only in a certain angle and doesn’t display in the 90 degree angle.
I have been using the same system using Airplay through my Apple TV and also using an external Display.
However not able to figure out the exact reason for the display not functioning.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
最有帮助的答案
Both the 13” & 15” 2016/17 MacBook Pro Touch Bar systems face the same issue its dubbed FlexGate!
Apple encountered a design defect that only showed up later in use with these systems displays. The cable that connects the display to the logic board backlight logic fails. Sadly, Apple has not fessed up on this defect and you’ll need to get your display replaced out of pocket, Ouch!
Here’s some good references:
Don’t forget to sign the petition here: Fix all MacBook Pro 2016 and later with stage light effect or backlight shutdown #flexgate
Save your paperwork! If Apple finally addresses this you should get a rebate.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Karthik Rupakula 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 5,686
