跳转到主内容
2015年十一月,华为发布了Mate 8。Mate8搭载了安卓6.0系统,具有6英寸的屏幕。有32GB以及64GB的内存,3GB的RAM以及4GB的RAM两个版本,一个16MP的后置摄像头和8MP的前置摄像头,一个4000毫安时的草鸡大的电池
touch screen not working after lcd screen replacement
after lcd screen replacement touch was working fine but after few hours it stop working and then tried with other new screen replacement but touch screen not working but display is fine
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
2条评论
hi
I have this problem too, in the top of the lcd socket, some parts of resistants has been breacked
but i dont find this parts to reinstal them and exactly dont know this problem directly affected to touch or not.
完成的
How can solve this
完成的
添加一条评论
1个答案
最有帮助的答案
If the screen was an cheap-repleacement part then it could be not suitable for your device. The good practice is to manage a hard reset of your phone after any replacement in order to get a new drivers adjusted to your component. Try that and then you should consider an PCB damage - not only the connector but whole ICs itself. The first thing that goes off when some one not provided goes into the device is an backlight IC, but in your case it could be just touch circuit.
Try a new display after an hard reset of device. Then go back to this forum and get better answer than mine.
Ps. After reading your post over again I would suggest to check for water damages. If the screen stops working after few hours it could be some dirt/corrosion on the motherboard near chips/capacitors
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
darshan kumar 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 33
总计 9,419
