跳转到主内容
Repair guides and support for a wide range of small engines.
103 个问题 查看全部
Atv would not run with old carb should I get new one
My 110cc Tao Tao 2007 110ah would not start it would start for like a few seconds then shutoff even while giving it gas i took carb of and could not get any of screws out to look inside they were all striped the atv has had compression and spark so if I buy I new one should that fix my problem
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Anthony,
I don’t know what a tao tao is, but it has a carburetor. Since you said it runs for a few seconds (good ignition) and has compression, the carb seems to be the culprit all right. I don’t know what carbs cost, but certainly a new one would be a quick way to find out of the old one was bad or not. If you are sure that gas is flowing to the carb, you’ve narrowed down the problem, although I’d work a little hard on getting the old carb apart. Have you tried penetrant and grabbing the screw heads with vice grips? If you do get it open, get some good screws for next time.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Anthony 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 61
