跳转到主内容
Hp Split 13-r010dx 13'' laptop tablet released in 2013. The device is identified by model number 13-r010dx located on the bottom of the tablet.
Can I install a SSD in my hp splitx2
I have an older HP Splitx2 touch laptop and would like to add a SSD to it. Is that possible?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
6条评论
Thanks MasterBuddy for your response. Being as how I’m no expert on doing this, I will use my Service manual to get it done. Do you have any recommendations for an SSD? Thinking 128GB.
As for the DVD Rom part, don’t have that - not OEM. I have an external DVD/CD reader/burner.
Is it necessary to get a new Hard Drive?
完成的
No - you can just replace your old HDD with brand new SSD.
The process is easy - you should unscrew the bottom plate (it is only for HardDrive, or HardDrive and RAM and WiFi or just one for entire bottom - check repairs on YT or so).
128GB is a bit to small. I've changed my 500GB HDD to 256GB SSD and it barely fits my demands. 250 is minimum for me, but after 2years I see that 500GB would be perfect.
I would suggest you to go into Samsung Evo for example, but any SSD will be a great upgrade for your HP. Just check the write/read speed - HDD is about 20-40 Mb/s and SSD should be over 500Mb/s. Keep in mind to search for SSD which has SATA interface (doesn't matter which SATA version)
完成的
Thank you MakerBuddy for your response. Your recommendation is exactly what I was considering on purchasing. It was rated best of top four. I really appreciate your time and help.
Samsung 860 EVO 500GB 2.5 Inch SATA III Internal SSD (MZ-76E500B/AM)
完成的
MakerBuddy. What is your opinion of this SSD?
Samsung - 860 QVO 1TB Internal SATA Solid State Drive with V-NAND Technology
完成的
860 QVO 1TB Internal - nice piece of tech; Samsung creates great devices and you could be certain about its spec
Samsung 860 EVO 500GB also great, quite faster, but that 1TB has better technology applied.
At the fact both are great. I personally use budget A-Data drive, but it fits my demands. Go for Samsung - you'll be happy :)
完成的
显示更多的1条评论
添加一条评论
1个答案
已选择的解决方案
Yes - go for it! And as soon as it is possible - your laptop will be grateful.
Since SSD discs work on SATA interface you can swap your Hard Drive to a new one (2.5” required). You can also dismount your DVD Rom and buy an pocket for external disc. But it should be picket for your laptop model.
这个答案有帮助吗?
得分 1
1条评论:
hey genius, maybe do a bit of research before giving a generic and incorrect answer. The factory installed drive in not a standard SATA interface...
完成的
添加一条评论
添加你的答案
Jack Anderson 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 16
总计 819
