跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
TriStar or Tigris?iPhone 6s plus
Hi, I have this iPhone 6s plus that has fake charging . I replaced TriStar already with no change. I noticed that when I plug in the cable , and afterwards I plug the battery it starts charging ( but stops drawing amps after a minute). If I have battery in and then I plug cable it is fake charging.
I tried brand new battery and it's doing the same.
It also do the bootloops on the cable plugged in , without battery.
Should I replace Tigris ? Maybe any ways to check it ?
Cheers
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi
Have you tried an another dock flex.
Further, what is the voltage of the battery connector with the charger plugged in without the battery. if the battery connector is above 3v, that normal and try tigris. if that is below 3v then that is placement of the tristar ic most likely
thanks
这个答案有帮助吗?
得分 1
3条评论:
Hi, thanks for the anaswer.
battery connector is 0.6v with the charger plugged in. I dont suspect dock to be bad as it works with itunes and as I said it does charge for a couple of minutes but then drops to 0.00A. I have ordered new tigris so I have to wait and see.
Tristar has been changed already so not the issue as well.
完成的
ok. 0.6 is too low. it has to be 3v or above. if you can please send a pic of the tristar area. it might be a placement or cold solder under tristar too
Thanks
完成的
Temporarily plug in another charger port and test charging, I have seen bad charger ports do this with a combination of a bad tristar.
完成的
添加一条评论
Is not about tristar IC, It caused miss comunication betwen connector battery to tigris IC.. there is short or missing componen FL/Cap/R or other..
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Michal 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 561
